brake line part number?
Discussion in 'The Garage' started by shaun89, Sep 28, 2005.
  1. shaun89
    shaun89 1/2 ton status
    Aug 7, 2005
    1,942
    center of CT..ish
    im putting a 6" lift on my truck and i need extended brake lines, i no steel braided are good but im tight on money so ill go with anything, im just wondering if anyone knows the napa part number for some extended lines? if u help me,ill be ur friend :wink1:
  2. Big89Burban
    Big89Burban 1/2 ton status
    Jul 19, 2005
    143
    Magnolia, Tx
    Just go to napa with your brake hose and find two unions (female on both sides) that have the same thread pitch etc. (will probably be like 3/16 line) Then just get a couple premade straight peices(they should have them in stock). Just use the unions from your brake lines to the premade peices and connect your stock hoses to the premade hard line.
  3. shaun89
    Aug 7, 2005
    1,942
    center of CT..ish
    ok thanks, ill give that i try.
