Brake line part # ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by wayne, Aug 27, 2001.
  1. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    I need to order brake lines for when I do my lift and axle swap. I am going to get the Pro Comps for now. I have a 89 with the 10 bolt now and will be swapping in a Dana 60. I should be able to just get the line for the 10 bolt because the 60 is the same size on the caliper as the 10. Does anybody have the part # I need so I can make sure I am getting the correct lines?
    <font color=blue>Wayne<font color=blue>
    <font color=blue>Happy Trails<font color=blue>
  2. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    So, 10 bolt brake lines are the same as D60s? I was just checking around for longer brake lines for my D60 but everyone I talked to gets really stupid when I try to talk to them about D60s. I actually had to argue with a guy at "Desert Fox Off Road" that 1/2 ton front springs would fit on a K30 and he flat told me that "they don't make 8 lug 15" wheels because they won't fit with any amount of grinding". Desert Fox is supposed to be one of the good off road shops around. [​IMG]
    Anyway, what did you come up with?
    Russ
    85 K30 CUCV, 350 TBI, TH400, 205, D60/C14, 4.56 Locked, 4" lift, 42" tires
    Some day: massive cutting, shorter wb and rear overhang.
  3. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    I thought my puter messed up or something after seeing this.[​IMG] I just ordered lines for a 89 GMC Jimmy with a 6" lift. They bolted to the D60 just fine. I think the guy at Desert Rat needs to put the crack pipe down.[​IMG]
    See <a target="_blank" href=http://coloradok5.com/gallery/Waynes-Toy>Project Mighty Mouse</a> here.
  4. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Hehe, SUPRISE. IT'S A BLAST FROM THE PAST! [​IMG]
    Some people (although from most of the posts, not many) do search before they post. [​IMG]
    BTW, can I run 15" wheels on my D60? [​IMG] Oh, and will my 35" tires fit with 4" lift?
    Sheesh, too early in the morning I guess. Yeah, that's my excuse. Thanks for the info...
    Russ
