brake line question
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by 69K5, Apr 18, 2004.
  1. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    is there any reason why i couldntuse the drum brake lines on the frtont for my disc? everything bolts up just wasnt 100 % so i figured id ask.
    also will 10 bolt lines fit a d44 or adapt to em?
    thanks
    69k5
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    10B and D60 are both 10mm and D44 are 3/8" threads. I think you could hook them up and it not leak but can't be sure...I am going to try it when I put in my D60. It should work as long as the banjo fitting is centered.
  3. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    i think i am gonna try the drum lines. when i tried em they cinched doown good. the only difference i saw is there wasnt a thingy that kept the fitting from spinning. and if it doesnt look good ill change it out.
