brake line question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mpascino, Nov 1, 2001.
  1. mpascino
    mpascino 1/2 ton status
    Jan 1, 2001
    557
    Connecticut
    Hi, as of now my front brakes suck. I just installed my Dana 60 along with new rotors, calipers and pads. I have power bled the entire brake system. Also when I installed the front end I put on new brake lines, rubber, about 26" long. My question, is it possible that my brake lines are too long? Can they be expanding when I hit the brakes and making my front brakes crappy? The rear brakes work well, even will lock up the 44's. Anyone have any ideas? I am stumped.
    Thanks,
    Mike
    The jeep eater ......jeep it's what's for dinner[​IMG]
  2. dragricinMT
    dragricinMT 1/2 ton status
    Jul 21, 2001
    135
    Billings Montana
    Make sure you have the calipers on the correct sides. The bleeder needs to be pointing up for the air to bleed out. if they are pointing down swap sides. I've seen it done before.
    Good Luck...
    78-K5 4"Lift 35"Tires 400SB TH350 NP205
    73 Vega 350SB TH350
  3. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    I would get rid of the rubber lines if they are that long. They will swell under pressure and I would not trust a rubber line that long. Just my $.02.
    See <a target="_blank" href=http://coloradok5.com/gallery/Waynes-Toy>Project Mighty Mouse</a> here.
    <font color=blue>Wayne<font color=blue>
    <font color=blue>Happy Trails<font color=blue>
  4. mpascino
    Jan 1, 2001
    557
    Connecticut
    yeah I've seen the upside down caliper thing before. First thing I checked , after all it was a late night. They brakes do indeed work jus tnot well. I guess the only thing lef tot try is shortening my brake lines unless anyone has any better ideas.....
    Mike
  5. taterblazer
    taterblazer 1/2 ton status
    Feb 2, 2001
    277
    Boise, ID
    Might be your proportioning valve? Do they bleed well? I doubt the brake lines swell much. Are they DOT certified?
  6. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    pro comp stainless steel lines, their niiiiiccccee!!!
    <font color=red>K5: Because size DOES matter</font color=red>
    85 K5 4IN LIFT 35 GOOD YEAR WRANGLER MT/R, AMERICAN RACING WHEELS
  7. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    Yeah, definately get SS brake hoses. Man, can't imagine Rubber hoses stopping 44"s too well. I have 34" SS hoses and my K5 stops on a dime [​IMG]
    Boss
    Pic of my truck Before N' After
    <a target="_blank" href=http://coloradok5.com/gallery/BeforeNAfter>http://coloradok5.com/gallery/BeforeNAfter</a>
  8. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Hey Boss, where did you get your SS lines? Part number? If I may be so rude as to ask, how much??
    Russ
    85 K30 CUCV, 350 TBI, TH400, 205, D60/C14, 4.56 Locked, 4" lift, 42" tires
    Some day: massive cutting, shorter wb and rear overhang.
