brake line ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bigblazer433, Aug 1, 2002.
  1. bigblazer433
    bigblazer433 Registered Member
    Jul 29, 2002
    38
    El Reno Oklahoma
    I got my 6in lift for my 87 blazer the other day and in the kit was two L shaped brackets with a hole at each end. Someone told me that it was for the front brake lines so if it is for the brake lines were and how does it go on there.
    there is nothing in the instructions about these brackets
    OH yah this is my first post here at coloradok5 /forums/images/icons/grin.gif
  2. Jersey
    Jersey 1/2 ton status
    Aug 14, 2001
    234
    NJ
    welcome to the board bigblazer. You found a great site for technical stuff on your K5. A lot of these guys are really knowedgable and have helped me out many times. I got those same brackes with my 4" rancho lift and mine were suppose to mount to the bolt that holds the front crossmembers to the frame. you're suppose to alos re-route your hard brake lines to these L-brackets. PITA. easier and better to go get the braided lines for a 6" lift. No flex in the line so better pedal and no need to re-route lines. just my opinion.
    - Jersey
