brake lines and steering colum
Discussion in '1983-2005 S-Series models' started by Confederate9, May 2, 2002.
  1. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    i am posting this for my friend
    we are goin to lift his 99 s10 blazer, with the 5inch trailmaster lift then torque it up w/ the torsion bars about 1.5 more inches.
    he was wondering if we do this will he have to get new brakelines?
    and would he need a new steering column
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The IFS lift kits that I've seen come with new, longer brake lines. You'll definitely need them with that much lift. Check with the manufacturer to see if they're included in the kit.
    A suspension lift won't change the relationship between the steering column and the steering box, so you won't have to mess with the column at all. /forums/images/icons/cool.gif That only becomes a problem when you install a body lift.
  3. Confederate9
    May 29, 2000
    1,686
    Greensboro NC
    it the trailmaster lift, and when he ordered it it didnt say what it included.
    soooo....... does anyone know if that kit comes with them?
  4. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
  5. Confederate9
    May 29, 2000
    1,686
    Greensboro NC
    well it doesnt come with brake lines
    anyone know where to get them?
    i dont think pro comp has them for this model
  6. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    You have 2 choices:
    1) Re-locate where the flex line mounts to the frame (what most of the kits say to do)
    2) Get longer lines
    If you want to get longer lines either go to a local speed shop and they should be able to hook you up, or try http://www.earlsperformance.com/html/
  7. 350S10NJ
    350S10NJ Registered Member
    May 16, 2002
    32
    Southern New Jersey, USA
    The TrailMaster kit gives you new brackets to lower the stock lines. If you have any questions call them, they were great to talk to when i got mine. I got it used from a rollover with no destructions for $45.00. They faxed me a set for free
    It's not hard to put on but takes some time. Took me about 24 hours over 3 days, of course i had to paint it all too in that time ( orange was fugly )
