brake lines and swaybar
Discussion in 'The Garage' started by tacoma972, May 29, 2002.
  1. tacoma972
    tacoma972 1/2 ton status
    Jan 6, 2002
    114
    West Point, Ga.
    i disconnected my swaybar and i am wondering if i will have to add longer brake lines at full droop. if i grab the brake line and pull it tight, it seems like i have about 4 to 5" of play. i have a 3" susp lift on and run 36" swamper tsl radials. i am sure their is someone out their with a good or bad experience. /forums/images/icons/smile.gif /forums/images/icons/frown.gif
  2. BILLY RAY
    BILLY RAY 1/2 ton status
    Dec 8, 2001
    1,319
    Austin, Tx.
    You will need to play with it. Just disconnect the bar and put a tire on a big rock and see if they get tight. I run real long brake lines and use a carb. spring to keep the line off the tire so when i'am at full flex the brake line pulls on the spring and lets the line extend.
  3. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    cool, he FIGURED out the SHIFT butTON
    thank you!
  4. BILLY RAY
    Dec 8, 2001
    1,319
    Austin, Tx.
    i made a mistake
