brake lines for 14bolt disk
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Seventy4Blazer, Mar 24, 2002.
  1. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    what did you do for brake lines on your conversion?
    custom lines?
    or is there a part number i can ger?
    anything special?
    Grant
  2. greg83k5
    greg83k5 1/2 ton status
    Nov 2, 2001
    230
    space sity houston, texas
    i believe the autozone # if you used 3/4 ton calipers is 77028 for flex lines.
    go to their website and plug that # in, i think that's it. i think i'm gonna buy a bending/flaring/cutting tool set so i can manipulate my own brake line.....
    greg
  3. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    how do i bolt it in to the block in the center? where it goes to one.
    does it match up right?
    Grant
  4. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    Grant,
    i just finished the disk install. i used the front brake lines since i needed longer ones for a 4" lift. funny cause i ran all over town looking for someone tor fab them. the answer was right in my hands. one side of the brake line is a square block, fits nicely on the cady calipers and the other end is a female 3/16. i used the hard brake lines from my 12bolt and pieced everthing together. i just need to bleed the brakes a bit more and some shock mounts :-)
    ARQ.
  5. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,089
    489
    Grand Rapids area
    Yes, it's almost too easy. Stock rear hardlines thread right into stock front flex lines and the stock front flex lines connect right to the calipers with banjo bolts.
  6. Kyle89K5
    Kyle89K5 1/2 ton status
    2,273
    OKLAHOMA
    I've got the stainless lines from TSM on mine. They work real nice. For the hardline, I notched my diff cover and bolted the block to the cover then bent my own hardline. I used the little clips that were already on the axle to hold it all together. Nice, quick, and clean. I played with about 3 different options before I just did the easiest I could find. Turned out well. You'll need a flaring tool and a tubing cutter, but autozone has got them for cheap. You don't need a whole lotta slack in the line, it doesn't move much at all.
  7. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
  8. UNCLE CRACKER
    UNCLE CRACKER 1/2 ton status
    Dec 29, 2001
    937
    PORTLAND OR
    you can get braided lines through TSM brake cor. the tie in with the steel lines i think there around 50 bucks
  9. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    problem is i have 10 bolt 3/4 ton callipers(this way they are interchangeable with D60)
    so i dont know if that will work
    Grant
