brake lines help
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Confederate9, Sep 17, 2001.
  1. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    i need help.
    where can i get extended brakelines for my 85 for a 4in lift.
    were exactlycan i get them i cant find em on central4wd.
    i needsome help, thanks
    <font color=red>K5: Because size DOES matter</font color=red>
    85 K5 4IN LIFT 35 GOOD YEAR WRANGLER MT/R, AMERICAN RACING WHEELS
  2. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    Procomp makes them, you can buy them through Summit.
    <a target="_blank" href=http://www.geocities.com/outlaw613/K5.html>http://www.geocities.com/outlaw613/K5.html</a>
  3. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    it's a lot cheaper to extend them yourself, especially if you only have 4" lift. i'm not sure of your articulation, but it is easy, safe and affordable to buy hard brake line and exten it out on a bracket to which the soft flex hose meets up with. i did it and it took 4 bolts two 8" pieces of brake hose, and diamond plate angle iron.
    Tork DSR
    I just got a winch, it takes the fun out of things.
  4. big75jimmy
    big75jimmy Registered Member
    Jun 26, 2001
    77
    Kirksville MO
    I just bought some brake hoses from 4 wheel parts, they cost my $100, this included s&amp;h to Missouri.
  5. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    Drop coopertwpk a pm he sels some pretty trick looking brake lines. I am pondering selling my 6" set to go with a custom length set from him.
    <a target="_blank" href=http://community.webshots.com/user/thatguydrew23>http://community.webshots.com/user/thatguydrew23</a>
  6. dragricinMT
    dragricinMT 1/2 ton status
    Jul 21, 2001
    135
    Billings Montana
    I'm running skyjacker hoses. You should be able to get hoses from just about any reputable 4x4 company.
    78-K5 4"Lift 35"Tires 400SB TH350 NP205
    73 Vega 350SB TH350
  7. Confederate9
    May 29, 2000
    1,686
    Greensboro NC
    yes i ordered the ones from summit
    the pro comp.
    is it much harder than just disconnecting the old hoses and putting on new ones?
    here is a link to what i got:
    <a target="_blank" href=http://store.summitracing.com/partdetail.asp?s=25&amp;p=2346&amp;part=5340>http://store.summitracing.com/partdetail.asp?s=25&amp;p=2346&amp;part=5340</a>
  8. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I have a similar situation here too. I have a 3" lift, so the hoses on there should be fine if I don't do any extreme off-roading. I looked at them yesterday, and it looks like I could heat up the bracket, and bend it down a little to gain some more length...anyone do this?
    90K5
  9. Predator
    Predator 1/2 ton status
    Jun 19, 2001
    130
    OKC,OK
    I read a while back in a mag that NAPA PN 38872, are longer stock-type lines. Anyone tried this?
  10. dragricinMT
    Jul 21, 2001
    135
    Billings Montana
    I work for NAPA and when I put my 4" lift on I went through the books and there were none long enough. I took the length of factory hose and thread size for ends and found nothing close. I will check that # out later this week and see if it is longer and by how much.
    73 Vega 350SB TH350
  11. Confederate9
    May 29, 2000
    1,686
    Greensboro NC
    how do i change out my new ones? jsut change the hoses?
  12. dragricinMT
    Jul 21, 2001
    135
    Billings Montana
    Just change the hoses and washers if it has them. Don't forget to bleed the brakes afterward. Good luck
    73 Vega 350SB TH350
  13. Predator
    Jun 19, 2001
    130
    OKC,OK
    I just went down to NAPA and checked into the 38872. I put one up against a stock type and these are 4-5" longer. They have similiar fittings and don't have the steel part like on the original. Looks like they will work great and get this.......less than 14 bucks a piece!!! So I picked up a couple for my truck along with 447 and 348 U-joints [​IMG] for my 14FF swap.
