Brake lines
Discussion in 'OffRoad Design' started by mouse, Apr 15, 2004.
  1. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    Stephen, I ordered many parts on Tuesday and included the info that my Blazer is on 3/4 ton axles - 14bolt rear and D44 up front. I forgot to emphasize that fact when I ordered the brakelines. Is there any way you could check to make sure that you have sent me the correct lines? I might not be able to get to the truck for a few weeks.
    Thank you. /forums/images/graemlins/k5.gif
  2. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Actually, the thing that really matters is what size the banjo bolt is in your front calipers. If you can measure that, it'll tell you for sure. It'll be either a 10mm or 7/16" bolt. Then we can check them to make sure.
  3. mouse
    Nov 10, 2003
    1,448
    Great Falls Mt
    Well I went out and checked and it was neither a 7/16 or 10mm wrench that fit - it was a 1/2" wrench that fit the banjo bolt head. The front axle is from a '76 3/4 ton, K20 pickup.
  4. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    if you have a 76 axle, its a D44 which will be the 7/16" banjo bolt
  5. mouse
    Nov 10, 2003
    1,448
    Great Falls Mt
    Thats what I thought - he was referring to the threat size and not the bolt size...thanks /forums/images/graemlins/waytogo.gif
  6. mouse
    Nov 10, 2003
    1,448
    Great Falls Mt
    Everything arrived today, I'll check the brake lines as soon as I get a chance. The first thing I noticed was the 1/2 ton u-bolts - they won't work on the 14 bolt /forums/images/graemlins/doah.gif I'll send them back as soon as possible for the right ones and let you know if the brake lines are wrong.
    Thanks for the quick delivery! /forums/images/graemlins/waytogo.gif
  7. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    oops. Give us a call and we'll sort it out.
  8. mouse
    Nov 10, 2003
    1,448
    Great Falls Mt
    Yeah I called. I just ordered an additional set of 3/4 ton u-bolts and will keep the extra 1/2 ton. I can use them on the truck that is giving up it's 3/4 ton axles for the blazer - it's being converted to 1/2 ton! /forums/images/graemlins/waytogo.gif
