Brake lines %@$*&!
Discussion in 'The Garage' started by ugly_blazer, Sep 22, 2004.
  1. ugly_blazer
    ugly_blazer 1/2 ton status
    Apr 12, 2004
    1,214
    When running hardline on a rear axle housing, what do you do with the extra line? The lines are too long. Can these be cut and re-flared? (professionally, I know my copper tubing flare block won't work) I could just coil it up, like they do at the master cylinder... /forums/images/graemlins/whistling.gif /forums/images/graemlins/doah.gif
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Three routes:
    1) Coil or bend it to take up the extra length.
    2) Cut your current line and re-flare the cut end - use a double-flaring tool available at parts stores for around $30-40.
    3) Go to a parts store and buy a shorter, pre-made hard line (cut to a certain length, flared, with fittings - for the length of an axle tube, probably about $3-4)
  3. diesel4me
    Jul 24, 2003
    17,584
    945
    Massachussetts
    Usually I just coil it up like a pigs tail if its too long,unless I'm working on a customers truck and they want it to look perfect,then I have to cut and re-double flare it--you can couple 2 smaller or different lengths together with a coupler also.I dont get to anal about brake lines appearance,where I live your lucky to get 1 year out of them before they rust through again--. /forums/images/graemlins/angryfire.gif
  4. ugly_blazer
    Apr 12, 2004
    1,214
    I will check into this. I just put disc brakes on my 14 bolt and want the lines to look somewhat cool when I show off my new brakes. /forums/images/graemlins/wink.gif
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Go to Autozone and rent the flaring tool. It works great and it's free to rent.
  6. hawkeye649
    hawkeye649 1/2 ton status
    Mar 26, 2004
    848
    New Hamp-shi-ah
    I bought the 3' lines from AutoZoned I believe. They were too long, so the left side of the rear flex line goes to the right wheel, and the right side of the rear flex line goes to the left wheel. It looks .... interesting. At the time I didn't have a flair tool. I purchased one from Sanel Auto, because I couldn't fine enough room to stuff over-long lines under the front of my truck for my after-market tranny cooler.
    I'll tell ya, it looks goofy when you have cooler lines that run infront of and over your bumper! /forums/images/graemlins/histerical.gif /forums/images/graemlins/whistling.gif
