Brake lines?
Discussion in 'The Garage' started by highrlr, Dec 9, 2004.
  1. highrlr
    highrlr 1/2 ton status
    Nov 29, 2004
    302
    Bismarck, ND
    Ok, my 4" lift is ordered and on it way for my '89 GMC Jimmy, what I was wondering is will the stock brake lines work for a 4"? maybe if I dont disconect the swaybar? I would buy longer ones but I plan on doing a 1ton axle swap this spring and I am not sure if brake lines for the 10 bolt will work for the 60/14bolt axles? anyone know if they will? Thanks for any help!
  2. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
  3. highrlr
    Nov 29, 2004
    302
    Bismarck, ND
    Thanks for the link but I cant get it to work? If the lines for a 10 bolt will also work for a dana 60 then I might just do steel braided lines right away, is that what the napa ones are or are they just regular rubber lines? How about a rear brake line, is that also the same from a 10bolt to a 14 bolt?
  4. highrlr
    Nov 29, 2004
    302
    Bismarck, ND
    never mind about the link, I just noticed that the thread was on the 1st page right under my post!
  5. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    LOL I saw that fixed the link too. They are rubber lines, but for less than $20 a side they are great. I think the rear part number is in there too, or you can get away with just dropping the hard line a bit unless you have a ton of droop inthe rear.
  6. highrlr
    Nov 29, 2004
    302
    Bismarck, ND
    Cool, I hadnt really checked out the rearend yet but Ill probably just try to relocate the hard line first and see if that gives me enough length, I will be running an ORD 4" shackle flip with stock springs and stock shock location for now so im not expecting real awesome flex until I move the shocks and get some longer travel ones.
  7. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    I just replied in the other thread and added some pictures.:waytogo:
  8. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    I got brake line extensions from NAPA that work very well. Lets me carry a spare and they were about $25 IIRC.
  9. la_blazer82
    la_blazer82 1/2 ton status
    Apr 12, 2004
    148
    SoCal
    I ordered 4" ProComp stainless braided lines from ORD. They weren't cheap; they were $97 for the complete set. I ordered a bunch of stuff from ORD at the same time, so it was just easier at the time. Buying them alone, I'd probably go with extended OEM rubber lines.
  10. highrlr
    Nov 29, 2004
    302
    Bismarck, ND
    Thats where I ordered all my stuff from also, I shoulda got the lines at the same time but i was unaware that I could use the same lines when I do my 1ton swap so I didnt want to spend any money on them if i couldnt use them a few months down the road.
