Brake Lines
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Ozzie Bigbird, Apr 25, 2005.
  1. Ozzie Bigbird
    Ozzie Bigbird Registered Member
    Apr 24, 2005
    6
    Melbourne, Australia
    G'day Guys,
    Where can you order up extended brakelines from.
    I have just bought a 74 k5 with a 6" lift kit and I have been told that the brakelines are tight.
    I have also purchased a 3" body lift kit that I will be installing once the truck arrives which will mean that I need longer brake lines.
    Any help is greatly appreciated.
    Cheers
    HARRY
  2. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
  3. Ozzie Bigbird
    Apr 24, 2005
    6
    Thanks mate!
  4. la_blazer82
    la_blazer82 1/2 ton status
    Apr 12, 2004
    148
    SoCal
    I got my extended SS lines from ORD, but they use the ProComp lines. You should be able to get these pretty much anywhere
  5. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    I got extensions from NAPA. They fit in between the stock line and the connaction. I'm sure that you can get the same from a local parts shop, just bring in your lines to match up the fittings.
  6. wraenking
    wraenking 1/2 ton status
    Apr 30, 2003
    1,493
    Toms River, NJ
    i went to a local brake shop and he had them made for 14 bucks per side. couldnt beat that price. he uses some guy in pennsylvania. i cant remember the name though
