Brake Lines
Discussion in 'OffRoad Design' started by shoudabinacowboy, Aug 25, 2005.
  1. shoudabinacowboy
    shoudabinacowboy Registered Member
    Jul 26, 2005
    82
    Gold Bar, WA
    I'm putting disc brakes on my '78 K25 and want to use Eldorado calipers to retain the e-brake. Will your stainless extended lines work for this application? Thanks.
  2. shoudabinacowboy
    Jul 26, 2005
    82
    Gold Bar, WA
    Ok does anyone know the answer to this question? Or where I can get some to fit? I gotta get this project done. Thanks.
  3. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    what discs are you using?
  4. shoudabinacowboy
    Jul 26, 2005
    82
    Gold Bar, WA
    I'm using the DIY4x 14 bolt kit with '78 Cadillac calipers. My truck is a '78. The rotors are stock fronts for my truck. Thanks.
  5. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
    will the calipers fit the discs good? i know the factory diameters are different.
  6. shoudabinacowboy
    Jul 26, 2005
    82
    Gold Bar, WA
    They're supposed to fit well. The rotors are still on their way here, so I'm not positive. There's a few people here who have this setup though. Anyone running this setup that can help?
  7. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    I got my stainless lines for my El Dorado calipers from TSM. It was $50 for any length. I forget the AN size, but just give them a call and they'll be more than happy to give you what you need. I know, a little expensive, but they do look nice. :D
  8. Stephen
    Sep 15, 2000
    4,228
    144
    Carbondale Colorado
    Just tell us the banjo bolt size and you're good to go, not a big deal. TSM's lines can be a little short unless you specify what you want. We go with a bit longer line to give a little slack when you remove the caliper and to let you loop the line over the leaf spring instead of under. It's usually a bit easier to work with that way.
  9. spearchucker
    Nov 17, 2003
    1,556
    Bay area, CA
    You mean I could've got my lines from you? :frown1: I didn't know that or else I would have given my money to you instead. Guess I should have asked. :doah:
