Brake Lines
Discussion in 'The Garage' started by 1979jimmy350, Jan 31, 2006.
  1. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    I am getting ready to swap axles and lift my k-5 and i have a few brake questions.
    1) I have a D44 right now and am switching to a 10 bolt front. Will the brakes i have now fit the 10 bolt or would i be better off to keep the 10 bolt brakes
    2) I am looking at upgrading to stainless steel front brake hoses what are the thread sizes that i would need for the D44 and the 10 Bolt.
    3) I am looking at the hoses that are a total of 16" in length is that enough for 4 inches of lift and maby six somday in the future?
    1979jimmy350
  2. Jishory
    Jishory 1/2 ton status
    Jan 8, 2002
    1,367
    Palmdale, CA
    the brakes are different if you are doing a 1/2ton to 3/4 ton swap, the 3/4 ton stuff is alot bigger
    alot of places sell extended braided stainless steel brake lines, depending on how much flex you are getting out of your front suspenion, imo its better to go longer and add some springs to the middle of the lines to keep the from contacting your tires and not having brake line limit straps. ord has info on the fittings and stuff if you really want to make your own
    http://www.offroaddesign.com/catalog/braidedbrakelines.htm
  3. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    The D44 should use a 7/16-20 banjo bolt on the caliper. The 10B will most likely use a 10mm banjo bolt. The fitting at the hard line should be a 3/8-24 threaded fitting. If you want to make it really easy on yourself, we sell Crown Performance brake lines. Send me a PM if you're interested.
    I run 7" of lift and I use 24" long brake lines. I don't need them acting like a limiting strap. ;)
  4. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    What about the calipers? My K20 used the caliper for a K10.
  5. onetonbb74
    onetonbb74 1/2 ton status
    Dec 1, 2005
    2,083
    Campbell, CA
    calipers are the same from 1/2 to 3/4 or 10 bolt to d44 it doesnt matter. Rotors are different. The banjo bolts are different and can be found at the junkyard if you have the wrong style standard/metric. I would get stainless steel flex lines for sure they dont deteriate and get them long for a 7" lift.
