brake lines
Discussion in 'The Garage' started by 1979jimmy350, Mar 8, 2006.
  1. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    I just bought some stainless steel brake lines for my blazer, i orderd them longer so i would not have to change them in the future if i go bigger lift. I got the front and rear lines 28 inches long. I am only at 4 inches of lift right now what is the best way to keep them from getting caught up on stuff?
  2. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    crap wrong fourm:doah: sombody want to move this for me
  3. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Done........
  4. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    zip tie them up
    28" in the back is way long
  5. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    That's what I did too. Use small zipties so that the zip tie breaks rather than the brake line if it ever binds up.
  6. hero
    hero Registered Member
    Oct 21, 2002
    65
    Omaha, NE
    Zip tie a low tension throttle return spring on to the hose. This will keep it out of the way, but if your suspension flexes enough that you need more it will give temporarily and then go right back to where it was. Use one that doesn't have a lot of tension though.
