Brake lines
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by wfahlgren, Oct 17, 2001.
  1. wfahlgren
    wfahlgren 1/2 ton status
    Dec 30, 2000
    157
    Northern California
    I am going to put a 6 inch lift on. What length brake lines do I need to run? Front and rear?
  2. wfahlgren
    Dec 30, 2000
    157
    Northern California
  3. ed rex
    ed rex Registered Member
    Oct 10, 2001
    63
    Penn Valley, CA
    Hi Jester, When I lifted mine with a 6" suspension lift, as you probably know it was the rubber lines that were stretched. Mine were initially routed through a hole in the frame. I ended up fashioning an 'L' bracked that I bolted to the bottom of the frame. It lowered the line down so that there was no more problem.
