Brake Lines?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Innerpiece, Apr 2, 2002.
  1. Innerpiece
    Innerpiece 1/2 ton status
    Feb 22, 2001
    Mississippi (Yee Haw)
    Hi All --
    How do I replace the rubber brake hoses on my 87? I think I've narrowed it down to the rubber hoses! They appeared to be original, and I need to know how to
    (1) get the old rubber off.
    (2) Put the new hose on.
  2. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    Fort Collins, CO
    Not too hard...I pull my calipers off and cleaned then real good when I did mine...Also, not is the perfect time to put on extended brake lines if you ever plan on lifting you truck...I have te ProComp 4-6" extended brake lines and LOVE em...
    You will just want to undo th ehose at the caliper and then use a flare nut wrench and undo the hose at the frame rail where it attaches to the hard line...not to bad...there is a "clip" of sort that holds the brake line to the bracket at the frame...life is much easier when you pop it off first (it is on the back side of the bracket../.
