brake lines.
Discussion in 'The Garage' started by btolenti, Oct 6, 2003.
  1. btolenti
    btolenti 1/2 ton status
    Sep 28, 2003
    644
    Gilroy, CA
    I have procomp extended brake lines for a 10 bolt front end. They are rectangular. Unfortunately the new axle I have has a round depression where the brake line bolts on to the caliper so the brake line will not mount. I was told it was a 10 bolt with 8 lug discs. Is it actually a DANA44 with 8 lugs? Can I use the calipers from my 10 bolt on the new front end? If not, does anyone have a part number for the extended brake lines from NAPA?
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    You can use the old 10 bolt calipers on a 44. There is some variation in brake calipers, depending on the age and who made them. Just use your old calipers, they should bolt right on.
  3. btolenti
    Sep 28, 2003
    644
    Gilroy, CA
    Well that's a relief. Thanks.
    I would hate to have some stainless brake lines go to waste.
