brake pads
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by delta9blazer, Mar 3, 2000.
  1. delta9blazer
    delta9blazer 1/2 ton status
    1,646
    Northern California, over by 7-11
    best brake pads?
    <font color=purple>delta9blazer</font color=purple>
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I use to work at a parts store and the semi-metaics are all very close to being the same from what I was told. Some of the higher priced Raybestas(NASCAR on the box) and even the Rancho flavor semi-metalics are said to last the longer.
    Late
    Rock ON!
  3. I use the carbon mettalic and they seem to last longer and brake better. More money though, they are like OEM pads !
    <font color=red>BigBurb<font color=red>[​IMG][​IMG]
  4. Corey-88K5
    Corey-88K5 1/2 ton status
    720
    Home: Michigan, Stationed: Hill AFB (Home of Moab.
    I've had a problem with the front brakes squeeking all the time. I got the softest pads available. My pads were from Carquest, and I think they were Reybestes also. If you get the semi-metalic's (organic) try and get ones with a lifetime warr. They wear out pretty quick.
    Corey
    88K5
    [​IMG]<font color=blue>Girls Like Guys In Bow Ties</font color=blue>
    <font color=red>http://www.geocities.com/corey_perez
  5. Jamie
    Jamie Registered Member
    47
    Johnstown PA.
    Performance Friction Pads at Autozone There around $25.00 but worth it. They are a carbon metalic pad. My blazer never stopped so good and there lifetime to. I use them on all my vehicals and suggest them to everyone I know. As you might have guessed I worked there also.
  6. Anglewood
    Anglewood Registered Member
    Mar 4, 2000
    5
    California, USA
    On my last brake job, I decided to spring for the more expensive Raybestos Carbon Metalic pads. They work great, and havn't given a squeak or sign of wear in 2000 miles. My mechanic says that he has had a set on his tow rig for 30,000 miles and they are still going strong.
    Anglewood
    '78 K5 Cheyenne
    http://members.xoom.com/CBlazer.1/bcbalazerpage.htm
