Brake part needed
Discussion in 'Parts & Trucks Wanted' started by Muddytazz, Aug 7, 2004.
  1. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Needed asap, its the piece that hooks the booster push rod to the brake pedal rod on a 1st [​IMG]
    anyone have one laying around?
  2. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
  3. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    ttta...someone has got to have one
  4. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    too bad it's not the same as second gens, pm me by thursday if you still need it, I have to go to tueson friday morning, I have a friend on the way with a rolled 72. He has it I am shure..
    Probably just for shipping cost, or a ck5 member sticker /forums/images/graemlins/whistling.gif
  5. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    I know where there is a 1st gen in a wrecking yard that had a power booster on it in Kennewick, WA. I probably wont have the time to get to it this week though since the yard likes to close early on weekdays and it is a u-pull it yard only.
  6. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Just looks like a normal clevis pin to me. I'm sure there are other places that would sell them but these aircraft ones come in many different lengths to get it to fit right with no play. They are also made to better tolerances and are made of better material then normal hardwear store pins.
    http://www.aircraftspruce.com/catalog/hapages/clevispins.php
  7. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Kenny, talk to clubba68(andrew)about it since its going on his rig.
  8. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Dan, its not just the pins I need, also needing the bracket that connects both the booster pushrod and the brake pedal rod together.
  9. kennyw
    Jun 9, 2002
    13,223
    94
    I also know from experience you can adapt the 73-87 brake booster and master cylinder onto 1963-72 trucks with out much effort too /forums/images/graemlins/thumb.gif That would make finding the parts so much easier.
  10. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
  11. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    you can but it take mods, more than most want to take on, 73-=up is a total different design and setup, 73 up are single rod and one piece unit as far as the linkage goes, and 73-up have no rod cage assembly and also dotn stick out so far into the engine compartment in most cases, depending on if is bendix or delco moraine unit.
  12. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Randy, link to pic doesn't work
  13. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    did it work now ?
    i see it in this thread but doesnt mean it is showing up for everyone else who hasnt visited there yet and doesnt have it in their cache yet,
    if it doesnt work then imagestation is garbage
    good luck
