Brake parts for d44 and 10bolt
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 1979Jimmy, Feb 16, 2002.
  1. 1979Jimmy
    1979Jimmy 1/2 ton status
    Nov 14, 2001
    696
    Danville Ca
    Does anyone know if any brake parts are interchangable from d44s and 10 bolts.
    79 Jimmy, 5" lift 35 M/T with a 383 puttin out 400hp and 450lb/ft. 4.11s Locked front and back.
  2. Rockjunkies
    Rockjunkies 1/2 ton status
    Jul 26, 2001
    385
    Oklahoma
    From what I understand, all the brake parts will interchange.
    built not bought
  3. aandpman
    aandpman 1/2 ton status Premium Member
    Sep 6, 2001
    151
    7
    Austin, Texas
    I think there is a slight difference in the banjo fitting for the brake lines.
    P. eople for
    E. ating
    T. asty
    A. nimals
    85 K10, 305 700R4 33's 3.08's (14bff & D44 in the garage now, w/4.10's ;-)
  4. WhiteWhomper
    WhiteWhomper 1/2 ton status
    Sep 23, 2000
    227
    Highlands Ranch, CO.
    Aside from the fittings at the caliper to brake hose being different, all else will interchange.
  5. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Rotors are the same. Calipers on a 10B have smaller banjo bolts than a D44. They all use the same pads.
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
    <a target="_blank" href=http://community.webshots.com/user/triaged>See it Here </a>
  6. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I am going to swap the 8 lug outers off a D44 onto my 10bolt, and question is will my calipers off the 10 bolt fit the d44? If not how can I change the fittings on my brake lines to fit a D44 caliper?
    My Chevy isn't broken, its just out of gas.
  7. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    You can just use your 10B calipers w/ the rest of the D44 8 lug stuff.
  8. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    hossbaby50, your 10 bolt calipers will fit the d44, you must use the caliper bracket from the 8 lug rotor though. rotors on the 8 lug are larger than the 6 lugs so that makes the bracket different.
  9. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Sweet, thats what I was hoping to hear. Now I won't need to figure out how to make the 10 bolt break lines fit the D44 Caliper. Thank you all for your help.
    Harley
