brake pedal dealie
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Jishory, Sep 1, 2005.
  1. Jishory
    Jishory 1/2 ton status
    Jan 8, 2002
    1,367
    Palmdale, CA
    im working on turning my truck to a manual, i took out the stock brake pedal "frame" with the old brake pedal and put in the new "frame" with the clutch pedal and new brake pedal but the bar that goes from the master cylinder to the pedal has a hole on it too small for the new pedal's "pin" that goes through it, and the bar doesnt have enough meat on it to drill it out bigger. what would be the best solution for this problem? cut off the pin and find some kind of specialty bolt that will replace it? replace the bar with one that came on manuals? how does that bar come out anyways? would i need to remove the master cylinder to replace the bar? :doah:
    thanks in advance!
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I have to go look at my stuff later , so I can compare older to newer .
    Couldn't you grind the post a little smaller ?
    Or maybe drill another hole above ( less force ) or below ( more force ) ?
    If you weren't able to find the right bolt , maybe a smaller grade 8 bolt with a tubing sleeve cut and slid over bolt , and bolt on the pedal pushrod with a washer and nut .
  3. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    josh... a step down bolt or cut the rod and put a larger peice on it... 5 minutes to weld it.... if you tell me what you want and send it to me Id be happy to do it at no charge for you
    cam
  4. Jishory
    Jan 8, 2002
    1,367
    Palmdale, CA
    i think im going to try the step down bolt... ill get back to you on that cam. thanks for the help
  5. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Use you brake peddle from the old setup. Thats wat I did.
  6. Jishory
    Jan 8, 2002
    1,367
    Palmdale, CA
    went ahead and just used the old peddle, works good :waytogo:
