Brake pedal to the floor
Discussion in 'The Garage' started by 84CUCV, Aug 3, 2005.
  1. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    Never really worked with them yet. only thing i can think of is there is air in it some where. if so do i really need to go buy some kind of kit to bleed them? Is there a free way?
    thx mike
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    bleed your brakes? there is a simple free way sure, but it takes 2 people. Start at the wheel farthest from the MC(Passenger rear). Top off the fluid, then have someone push the pedal to the floor. Brake the bleeder loose, then close the bleeder after a few seconds and have the person let up on the brake, but NOT UNTIL AFTER YOU CLOSE THE BLEEDER! Continue to do this until all you get is fluid(not burst of air followed by fluid). Then move to the driver rear wheel, passenger front then finally the driver front, repeating the process all around. Remember to check the fluid level often and make sure the caps is on the res.
  3. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Yeah, and pump them a few times before you push to the floor...
  4. big_truxx
    big_truxx 1/2 ton status
    Oct 8, 2004
    2,272
    Canaan, Maine
    you can also gravity bleed them. if you are working alone.
  5. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    Thanks guys will get on it....
  6. dyeager535
    26,981
    Not to be picky, isn't the drivers side rear tire furthest away?
  7. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    If you really want to be picky, both rears are the same distance(drop line in center of rear).
  8. big_truxx
    Oct 8, 2004
    2,272
    Canaan, Maine
    :haha: we have too much free time around here sometimes :D
  9. dyeager535
    26,981
    No, I wasn't trying to waste time, I was just curious.
    What Sled said is true, both use the same line until the split at the rear axle, which is essentially the center of the truck, thus the same length to either wheel in the rear. If they were seperate all the way back, it would be a different story, but they aren't! :D
  10. big_truxx
    Oct 8, 2004
    2,272
    Canaan, Maine
    and i was just laughing :screwy: :p:
