brake pedal won't return
Discussion in 'The Garage' started by gravdigr, Mar 17, 2004.
  1. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    brake pedal won\'t return
    During the buildup of my blazer I recently replaced my entire brake system from the master cylinder to the calipers/rear cylinders. The only part I reused was the vacuum booster. I finished bleeding everything and the brakes work great except that the brake pedal doesn't return all the way up. I have to hook it with my foot. And when the pedal is stuck down the brakes stay engaged. I checked my shop manual and for my year it lists every model as having a brake return spring except for the c/k models. Any ideas?
  2. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Re: brake pedal won\'t return
    Should have a return spring.
