brake problem (added symptom)
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JIMs70K25, Jul 27, 2006.
  1. JIMs70K25
    JIMs70K25 1/2 ton status
    Dec 31, 2001
    524
    Chesapeake, VA
    I think it's a bad booster, let's see what you all think:
    At idle pedal is hard as a rock, moves but real hard and slow. After getting up to speed, brakes are fine, except after stopping when I start rolling forward slowly the pedal gets hard again. I don't have to pump the brakes. Can't find any leaks, I pulled the vacuum line from the booster and heard the rush of air, same with the vacuum canister on the firewall. Noticed something today, when the pedal is depressed at a stand still I can here a "hissing" sound. Also in park, running, pedal pushed my RPMs rise a little.
    This is with my 89 burb. Thanks,
  2. mike n
    mike n 1/2 ton status
    Oct 9, 2003
    101
    New York
    Booster is no good.
  3. JIMs70K25
    Dec 31, 2001
    524
    Chesapeake, VA
    yeah, but trying to find one is a pain in the butt. all 4 of the different chains(napa,autzone,advanced,carquest) in the area have to "order it", seems they are plentiful down south and out west. Just not in virginia.
  4. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    I just threw away that whole setup, still on a 89 sub. I would have gladly sent it to you for the shipping costs.
    I agree, its probably the booster, but check the vacuum line going to it for cracks first. Be sure to look at the check valveclosely too as they can cause leaks. Finally, the rubber adapter on the booster could be the source of a leak....but if you don't hear a hiss, then its probably not a vacuum leak.
  5. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    We had the same thing you're talking about occur on our 94 Suburban. I'd go ahead and order the part and drive the thing. We drove our for a couple of months before we sold it. Had a couple of harrowing emergency stops but as long as you pay attention and maintain a decent distance in front of you, you shouldn't have any issues.
  6. JIMs70K25
    Dec 31, 2001
    524
    Chesapeake, VA
    Fixed, Thanks!
