Brake Problem
Discussion in 'The Garage' started by nemesis_pyros, Sep 3, 2004.
  1. nemesis_pyros
    nemesis_pyros 1/2 ton status
    Mar 24, 2004
    229
    Winnipeg, Manitoba
    Ok so I just changed a siezed wheel cylinder on the rear drivers side and now after bleeding both sides I get a very soft pedal and spongey brakes. I dunno whats wrong I checked the fluid level and its fine but the brakes now suck and when I easily push the pedal to the floor the brake light comes on in the dash. Please Help I need to drive this thing tomorrow
    p.s. I bled the brakes with one man on the pedal holding it down and another opening the bleeder then closing it and letting off the brake pedal and repeating till no air came out.
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    sounds like you need to bleed it some more
  3. dyeager535
    26,979
    You need to replace the master. The brake light is telling you fluid is leaking somewhere, and if the leak isn't external, the ONLY place for fluid to "leak" is in the master cylinder.
    Chalk this one up to bleeding a used master cylinder. Not your fault, only way to prevent it is to powerbleed, NOT use the pedal.
    Exact symptoms I had after bleeding my used master cylinder, it actually lasted about 4 months before the light came on and I lost all brakes at one point, but the pedal was NEVER firm after trying to bleed it.
  4. kick
    kick 1/2 ton status
    Dec 19, 2002
    385
    FL
    I would gravity bleed the master cylinder and then bleed front and rear brakes calipers and wheel cylinders in sequence. RR, LR, RF, LF. Unless you have ABS or a diagonal split system then refer to your manual for the correct bleeding procedeure.
  5. jwduke
    jwduke 1/2 ton status
    Aug 25, 2001
    721
    Ice Cream Capital of the World, IA.
    I think you have to bench bleed a master cylinder. Gravity bleeding isn't going to do it.
