brake problem
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by skyblazin, Jun 12, 2002.
  1. skyblazin
    skyblazin Registered Member
    Jul 10, 2001
    7
    portland or
    ok guys i need your help. every other problem i've had i read the post and get the answer from them . this time i haven't seen this problem.driving down the road start braking and i get a metalic noice. new brakes, rotor turned, new bearings , new ball joints, i took the wheel off and i think the calipor bracket is flexing into the wheel. has anyone had this problem. could it be metal fatigue. or is it bent,could i weld something in there to make it stronger. i'm at a loss here.any ideas.i want to put 1 ton running gear on it in the future so i don't want to dish out a lot of cash now. thanks in advance
    scott
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    It is hard to tell what the problem could be without taking a look at it.
    If you do find that the backing plates are bent I am sure you could find someone who has some laying around after a 8-lug conversion. Or you could just do the 8-lug conversion now insted of later.
  3. ed rex
    ed rex Registered Member
    Oct 10, 2001
    63
    Penn Valley, CA
    Are you running 15 or 16 inch rims? With 15" rims I was getting rub from the diskbrake (front brakes) caliper to the inside of the rim. I ended up grinding down the caliper with the Makita grinder to make room. Didn't want to put a wheel spacer on.
  4. 68 Suburban
    68 Suburban Registered Member
    Apr 9, 2002
    42
    Phoenix, AZ
