Brake problem
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BigBadCad, Aug 2, 2002.
  1. BigBadCad
    BigBadCad 1/2 ton status
    Dec 18, 2001
    109
    minneapolis, mn
    I'm experiencing an intermittent grinding sound from my front brakes under light braking pressure. I pulled the wheels and checked the outside surface of the rotors and pads and everything appeared all right. Before I go commando and tear everything apart, are there any other quick checks I can do to isolate the problem?
  2. HispanicPanic
    HispanicPanic 1/2 ton status
    Mar 21, 2001
    351
    El Paso, Texas
    <font color="orange"> what you can try is sandpapering the roter and pads by hand of course and then spray brake cleaner on them to see if that helps just my .02 /forums/images/icons/wink.gif </font color>
  3. MilpitasK5
    MilpitasK5 1/2 ton status
    Nov 13, 2001
    889
    Milpitas, Ca.
    I'm not expert but that sounds like it might be that little piece of sheet metal that connects to the break pad to indicate new pads needed soon. If this is it, eventually that grinding noise will keep sounding as you roll without tapping on the breaks. Just my .02...
    Or you might be missing one of those caliper bolt washers. The break caliper bolt should have a washer on each end to keep the bolt from having play.
