Brake problem.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 85 Shortbox, Sep 30, 2002.
  1. 85 Shortbox
    85 Shortbox 1/2 ton status
    Jan 24, 2002
    138
    Grandville, Mi
    I blew the steel brake line running to the rear and replaced it. Then I went to bleed it and nothing happens. Feels like it is just sending pressure to the front. Any ideas? Thanks
  2. rh88k5
    rh88k5 Registered Member
    Sep 11, 2002
    94
    Burlington, N.J.
    Did your master cylinder go dry? Might have to bleed that too!
  3. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Well I hope you don't end up with what I had, same thing happened, and we tried so many things after that and nothing seemed to work untill we changed the lines and the master cylinder.
    The problem was moisture in the cylinder and some gunk from moisture in the lines. We could have just blown them clean but we prefered going with new.
    I would suggest purging the whole system and the best way is to unhook all the ends and blow the lines clean and then putting new brake fluid and bleeding all the connection from back to front, and remember it's always best to change all the fluid every 2 years, because brake fluid has the tendency to absorb moisture and that ruins seals and makes spungy pedal feel.
    IceMan
