Brake PROBLEMS continue...PLEASE help me out
Discussion in 'The Garage' started by BozoWise, May 10, 2002.
  1. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    I am removing my front and rear axel on the old K5 and can't seem to get the brake lines loose. I am trying to remove the flare fitting at the metal line coming from the frame in the rear and it will not come loose. I have soaked it in rust eater and all it is doing is stripping the nut. Is there any way to reflare the metal line and put a new nut on it. I am about to get the vise grips after it if so. I need to get this loose so I can put in an extended brake line for the new 14FF. Thanks for the advice.
  2. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    Just cut it off. I replaced all the metal lines from the front to the back when I did mine. The metal lines are cheaper than youd think, and by the sounds of it, you only need the ones from the T join to the frame.
    Price them out. Lots easier than reflaring and messing with the old ones.
    Mike
  3. 85HeartBurb
    85HeartBurb 1/2 ton status
    Jan 10, 2002
    735
    Temecula, south
    yes it would be cheaper to replace the lines i just did it on my 12 bolt the line was like 4 bones but they do sell flairing tools at the local parts stores!!
  4. BozoWise
    Mar 28, 2002
    1,224
    Lubbock, TX
    Where did you guys get your new lines?
  5. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    You could probably get them at Nape or some other parts place. Or the dealer.......
  6. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Kragen has them in various lengths. Napa will too.
  7. BozoWise
    Mar 28, 2002
    1,224
    Lubbock, TX
    Do I just measure the line length and buy it pre cut with ends and bend to fit? The prebent stuff from LMC is high dollar.
  8. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Thats exactly how I'm doing mine.
