Brake Problems... no pressure when truck running
Discussion in 'The Garage' started by goblazeinco, Feb 13, 2004.
  1. goblazeinco
    goblazeinco Registered Member
    Nov 9, 2001
    33
    Longmont,CO
    I have an '86 K5 with power brakes. I recently replaced the master cylinder, front calipers and did the disk conversion on the 14bff rear. I used the Dana 44 disks and calipers on the rear.
    My problem is that when the truck is off the pedal is very firm...but when I start the truck the pedal goes to the floor. Its not a bleeding problem...trust me ..I have bled the master and all the calipers to the tune of 4 quarts of fluid.
    Does anyone have any better ideas than taking it to a shop?
  2. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    Might be a bad power booster
  3. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    I'm thinkin ya got a bum master cylinder, i have had power boosters go bad, and when they did the pedal was harder than manual brakes. You said you installed a new master cylinder? where did you buy it at? /forums/images/graemlins/thinking.gif
  4. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    If your not getting any pressure, replace the master cylinder and you'll be golden /forums/images/graemlins/thumb.gif
  5. goblazeinco
    Nov 9, 2001
    33
    Longmont,CO
    The master is from Auto Zone. Thanks for the help guys, I will probably swap out the master again and see what happens. Once I get some pressure I can see if I need a proportioning valve for the larger rear brakes. I have read that some people need them and some people dont.
    Well, thanks for the help.
