brake problems when wet...
Discussion in '1936-Present Suburban' started by Kartoon, May 22, 2006.
  1. Kartoon
    Kartoon 1/2 ton status
    Jun 14, 2005
    171
    Massachusetts
    i have a 1990 suburban and after my truck as sat in the rain, when i get in it the front brakes lock up HARD when i barely touch the pedal. once i pump them a couple times or come to a stop a couple times it goes away and everything is fine. I have had them looked at but was told they are ok. but its obviously not. also, i can hear some sqeaking from them when they lock up like this.
    do i need new rotors, pads, or rebleed the brakes?
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    That's usually a sign of oil on the pads. (Are you sure it's the front brakes that are locking? It usually happens with the rear drum brakes.) Lots of brake cleaner on the rotors and new pads should clear it up.
  3. Kartoon
    Jun 14, 2005
    171
    Massachusetts
    when i have this problem and then stop in dirt, both front wheels leave skid marks.
