Brake Problems
Discussion in 'The Garage' started by big jimmy 91, Jan 12, 2005.
  1. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    My 91 jimmy had the brake light come on and stayed on about a week ago...
    After looking for the obvious things , nothing seems wrong:dunno:
    Tonight the light started flashing in a constant sequence of four times , a pause , four more... and so on
    It also seems that the brakes have become super touchy now , just look at the pedal and they lock up:confused:
    Does anyone have any idea what's up with the light and how touchy they are?
    This truck is all stock as far as I know and has some sort of anti-lock system on it.
    Any help would be appreciated as it is my only set of wheels right now :)
  2. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    IIRC the light has two purpose's one to let you know when the e brake is on and second to tell you when the brake system is under 50%, so you might want to take a peak at the master cyclinder for fluid level, check hard lines for kinks or leaks and really just every line on the truck, if you dont find anything i would then bleed all four courners to make sure that fluid is getting to them, being a 91 i think the only difference is the t case not having a mech speedo but could be wrong
  3. big jimmy 91
    Feb 21, 2004
    639
    Does anyone have any manuals for brake systems on a 91 jimmy , or know how the abs.system woks on them?
  4. big jimmy 91
    Feb 21, 2004
    639
    TTT , I need info if anyone has it.:whistle:
  5. big jimmy 91
    Feb 21, 2004
    639
    Last try , no one has any info? :confused:
  6. dyeager535
    26,980
    The light serves to indicate the parking brake is on, and also, if there is a problem with the computer controlled systems, to indicate which part is potentially the problem via a code. Sounds like it is giving you a code 44, but I didn't think that was something the system would do unless you used the paperclip trick to jumper ALDL connectors A&B.
    In any case, probably a problem with the ABS system, just guessing based off of your symptoms.
  7. big jimmy 91
    Feb 21, 2004
    639
    Thanks for the info :)
    Could anyone tell me what a code 44 would be?
