Brake Problems
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by cleszkie, Dec 10, 2001.
  1. cleszkie
    cleszkie 1/2 ton status
    Apr 23, 2001
    121
    Santa Ana, CA, USA
    Over the course of about a week the brakes on my 72 K5 seemed to be getting worse. I have power brakes (disks up front, drums in rear). The peddle has become very dead (hard). I checked all of the pads, bled all of the lines several times over, bench bled the master cylinder, but still have the same problem. Could this be a problem with the booster? When bleeding the brakes, I made sure to hold in the metering pin on the combination valve, but the pin did not seem to give any resistance. I expected it to feel "spring loaded". Could there be a problem with the combination valve? Any advice is appreciated.
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    It most likely is your booster. Air in the lines will make the peddal feel soft not hard.
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
    <a target="_blank" href=http://community.webshots.com/user/triaged>See it Here </a>
  3. POFF
    POFF 1/2 ton status
    Aug 13, 2001
    221
    San Diego, CA
    Check the vacuum hose to the booster first.
    Never said I could spell!
    '70 K-20 San Diego, CA
  4. Ryan B.
    Jul 18, 2001
    5,693
    CA
    as well as the check valve where the vaccuum line goes into the power booster.
    "suck &amp; blow" and air should only be allowed to go in one way.
    [REAL MEN DON"T CARE ABOUT GAS MILEAGE!]
    Ryan B.
  5. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Isn't a "hard" pedal a possible indication of a frozen wheel cylinder or stuck caliper?
    That might explain why bleeding isn't helping.....
    -Greg72
    '72 K5 Blazer - 427BB/TH350/NP205/6" Lift/35x12.50's
    <font color=blue>See it here: </font color=blue><a target="_blank" href=http://coloradok5.com/gallery/albun38>http://coloradok5.com/gallery/albun38</a>
  6. cleszkie
    Apr 23, 2001
    121
    Santa Ana, CA, USA
    Thanks for all the input. All my brake cylinders are in good working order, so I'm focusing my attention on the booster and/or vacuum lines/valves.
