brake problems
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by coolhandluke, Jan 8, 2003.
  1. coolhandluke
    coolhandluke 1/2 ton status
    Oct 23, 2001
    116
    Dallas Texas
    last weekend I swapped axles to a 14bff and the heavy duty, 8 lug 10 bolt front. everything was fine (well, not really, but that's a different story) drove it for a couple days no problem, then my brakes start getting mushy and the brake light comes on.
    what's the light actually sense? I don't seem to be low on fluid, so what's the deal?
  2. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    the proportioning valve senses an imbalance of pressure in the brake system. make sure your rear brakes are autoadjusting the drums...also make sure they're bled real well.
  3. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,073
    486
    Grand Rapids area
    The light means that the front and rear circuits have a lot different pressures. Either you have a leak or there is air somewhere. Air will make the pedal mushy. Also, if the shoes are too far from the drums, you will get extra pedal travel. You may be able to determine this by pulling on the parking brake and seeing where it engages.
  4. coolhandluke
    Oct 23, 2001
    116
    Dallas Texas
    parking brake, ha! that's a good one, we don't need no stinking parking brake!
  5. dyeager535
    26,977
    Thats what you think until the trannies park pawl lets go on a hill. It happens.
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    yep! have had this happen many times in auto and manual trans vehicles, mainly trucks, the 79 k10 was the last truck i had park problem with, was th350 203 truck. never had the problem in a 465 or 420 trruck though, just three speed and th350 ones so far
    good luck
  7. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    replace the mater cylinder. i did and it works great now. No idea why the M/C seems to fail after 1-ton swaps, but it does. I think it is the massive rear brakes
  8. dyeager535
    26,977
    Bleeding the brakes alone can cause failure, so after an axle swap, that makes sense. Even if bleeding weren't necessary, if the pedal has any more travel than before with the new axle (different brakes) then the same thing could happen.
  9. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Yep like Dorian said, bleeding an old MC will most of the times destroy it's seals.
    They are so cheap that usually for time saving when I do major work in the brake system I change the MC without thought, the time saved will more than compensate, if I had to bleed the original, then it fails and I have to change it and bleed again, not to mention the hastle and the lost fluid.
    /forums/images/graemlins/thumb.gif
