Brake prop valve
Discussion in 'The Garage' started by cegusman, Feb 14, 2003.
  1. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Is the prop valve from a 1ton the same as one for a 1/2ton?
    If they are different what is the difference?
    I am getting ready to do rear disks, would it be a good idea to get this 4 wheel disk prop valve
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    That might be a nice clean way to do it but I would rather gut the stock prop valve and use a adjustable prop valve in the rear line...too rich for my blood.
  3. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    My stock one is so badly rusted, the brake lines will not come off. Plus it has a hairline crack that leaks"so no rear brakes. So I have to replace it, would it be better to just get a 1ton one disc/drum and a adjustable prop valve, or just get the one stated above disc/disc?
  4. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    On more thing it will cost either $99 for the disc/disc prop valve or $150 for the disc/drum prop valve plus the adjustible prop valve.
  5. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    seems like you answered your own question. $ for $
    the difficulty with an adjustible prop valve is how do you adjust it.
    if you set it up for wet weather/winter braking it will be rear biased in the dry(rears will lock due to greater wieght transfer in dry)
    and vice versa.
    I would get the 4 disc one as you are needing a replacement.
    I would shop around a GM parts counter to see if the price you have is a fair deal.
    did you search the forum for the many good previous prop valve threads
  6. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I'd like to know how it works for you if you go with that $99 prop valve. I've looked at that several times and have wanted to buy it, but I don't know how good the valving is for a truck... Might still need a Wilwood prop valve inline with the rears.
    -- Mike
  7. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    I went ahead and ordered the disc/disc prop valve, I will let everyone know how it works. Truck just may be down for another 2 nonths.
  8. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    definitely let us know because i will be running the stock one to see how it runs before i replace it.has anybody ever used a cadilac proportioning valve for the dual disk setup it has?just a thought if it fits correct.it would be a bolt on gm part then if it is the same size as the blazer.maybe i'll be the test pig and go see if it works. /forums/images/graemlins/deal.gif
