Brake Proportioning Valves
Discussion in 'The Garage' started by AkMudr, Feb 15, 2005.
  1. AkMudr
    AkMudr 1/2 ton status
    Dec 30, 2004
    917
    Alaska
    Does anyone make a prop valve for disc/disc setups on '80's chevy trucks. I do believe mines takin a **** cuz I'm gettin no rear brakes... no air in the lines, everythin adjusted right and my booster,MC, rear shoes and wheel cylinders are all good.
    Is usin a 4 wheel disc prop valve the preffered method? Or is it better to run a stock prop valve with the addition of aftermarket valve?
  2. wraenking
    wraenking 1/2 ton status
    Apr 30, 2003
    1,493
    Toms River, NJ
    www.inlinetube.com
    they will hook you up. just call them and tell them what you have.
    im running theres and so are a few others.
  3. sweetk30
    Nov 1, 2004
    25,548
    543
    horseheads , ny 14845
    stock valve is t frt and adjust rear. replace with t in frt and put adjustable unit by the master for easy accsess and plum it hard to rear. then bleed and test drive and set to your liking.
  4. AkMudr
    Dec 30, 2004
    917
    Alaska
    Whats the goin $$ for one?
  5. wraenking
    Apr 30, 2003
    1,493
    Toms River, NJ
    40-50 for the adjustable, around 85 for the one form inline
    worth the extra money. why adjust when you dont have to?
  6. AkMudr
    Dec 30, 2004
    917
    Alaska
    Yeh, if I already hafta replace my stock prop valve I might as well go the extra step and get a disc/disc valve, would work just as well and cost less than buyin a new stock valve and an aftermarket valve to adjust the rear.
  7. wraenking
    Apr 30, 2003
    1,493
    Toms River, NJ
    exactly!
  8. AkMudr
    Dec 30, 2004
    917
    Alaska
    Which is why I am on the prowl for a disc/disc valve:D:D Plus thats less **** to adjust and 1 less thing to go bad. Inline tube is closed already, I'll holler at them tomorrow and get one ordered.
  9. sweetk30
    Nov 1, 2004
    25,548
    543
    you dont need a stock valve for the setup if you use a t fitting for the frt and adjustable for the rear. all the stocker does is t the frt and pre set pressure for the rear adjusted.
