Brake pull to right
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by antta99, Feb 7, 2004.
  1. antta99
    antta99 Registered Member
    Feb 7, 2004
    24
    windsor,ct
    Ever since I bought my truck it has had a pull to the right under moderate to heavy braking. Ive replaced the calipers,pads,drums,wheel cylinders and shoes.The truck has braided steel lines on it from the prevoius owner. The alaigment is good as are the tierods and stuff. Any suggestions? /forums/images/graemlins/1zhelp.gif
  2. rock.monkey
    rock.monkey 1/2 ton status
    Oct 28, 2000
    296
    100 Mile house B.C. Canada
    Check that the shoes are adjusted close to the same and that both adjusters are working properly.
    Having 1 drum out of adjustment will cause a pull under those conditions. /forums/images/graemlins/k5.gif
  3. 99firehawk
    99firehawk 1/2 ton status
    Dec 15, 2002
    491
    Check your shocks, your shackles your springs your spring bushings, sway bar bushings, tire pressure.
  4. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    Is it lifted? You may be experiencing bump steer.
  5. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    yup
  6. antta99
    Feb 7, 2004
    24
    windsor,ct
    Its lifted 2 1/2 inches. I was thinking about putting a drop pitman arm on it.Thanks for the ideas.
  7. Grim-Reaper
    7,385
    Atlanta
    Check ball joints and TRE's Also even with a 2.5 inch lift is messes up the geometry on the sway bar. Unbolt it and see if it goes away. If you want ot keep the sway get the ORD correction/disconnect kit. Makes a big difference. Steering brace also make a big improvement in handling both on and off road. I run both thos parts on my 75 and it has better ride and better feel under braking then our stock 79 did.
  8. Stickseler
    Stickseler 3/4 ton status
    Mar 23, 2001
    6,503
    Northern Virginia
    Mine was doin this after my 2" lift. I took it in for alignment and a brake check. They pulled a tape and said my rear axle was a hair forward on the right which made the rear want to goto the left and the front to the right under braking. I figured Id fix it when I shim the back eventually and see.
