Brake pull
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Mr. Jimmy, Aug 21, 2002.
  1. Mr. Jimmy
    Mr. Jimmy Registered Member
    Mar 14, 2002
    63
    Haynesville Ga.
    How many of you have had brake pull problems after installing either 4" or 6" lifts. I bought my 89 Jimmy with /forums/images/icons/smirk.gif a 6" lift already installed and can't get rid of this problem which seems to get worse after truck has been driven for a while.
    Thanks, Keith
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> The problem is more likely something wrong in the brake system than the lift. Sticky caliper, bad wheel cylinder, something like that. I don't see why a lift would cause it to pull only when braking.</font color>
  3. OLDSTEEL
    OLDSTEEL 1/2 ton status
    Mar 11, 2000
    107
    SANDIEGO CA
    I agree with shaggy you need to take a hard look at your brake system.
