brake pushrod adjustment?
Discussion in 'The Garage' started by 88sub4x4, Mar 4, 2004.
  1. 88sub4x4
    88sub4x4 1/2 ton status
    Sep 22, 2002
    792
    Long Island, NY
    I have an 88 sub, 1/2 ton braking system. I was just wondering if the pushrod, the one that goes from the pedal through the booster to the master cyl, is adjustable, and if so how? When I step on the brakes the pedal goes halfway, and then starts braking. The truck has always done this, so I don't know if it's normal. The rears are adjusted properly, and I just put in a new master. Any suggestions?
    Thanks, shaun
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Tighten your rear brakes more.
  3. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    My booster and master cylinder both came with some instructions on adjusting the length of the pushrod. You should look it up in a shop manual.
    Are you sure there is no air in the lines? It sounds like you still need to do some bleading to me.
  4. jwduke
    jwduke 1/2 ton status
    Aug 25, 2001
    721
    Ice Cream Capital of the World, IA.
    Yes, the push rod is adjustable. I works best if you cut the unthreaded part of the threaded sleeve off, then use a thin jam nut. Try a couple of threads at a time. This does work, I did it to my '87.
  5. 88sub4x4
    Sep 22, 2002
    792
    Long Island, NY
    I power bled it when i put the master in, and I re-bled it last night, no air came out. The rears are nice and tight, I will try to adjust the pushrod.
    Thanks everyone, shaun
