brake question
Discussion in 'The Garage' started by skelly1, Apr 30, 2004.
  1. skelly1
    skelly1 1/2 ton status
    Sep 2, 2002
    554
    San Diego, CA
    I installed a 3/4 ton axle settup and I replaced the master cylinder with a 3/4 ton. This blazer is a 1990, and the ABS computer is long gone. The brakes seem to work ok, but I don't understand what the ABS did before. Would it feed the proportioning valve somehow? Should I use a different proportioning valve? The new master is a new Napa master with the application for a 1990 3/4 ton. The reservoir on it is a little smaller than the old one, and the back brake line tube has a bigger orifice than the old one.
  2. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    The ABS controller would have pulsed the pressure to the rear wheels not allowing them to lock up. If its working fine this way I wouldnt worry about. Ive unplugged many of these before and never had a problem /forums/images/graemlins/thumb.gif
  3. skelly1
    Sep 2, 2002
    554
    San Diego, CA
    Thanks, so it pulses the pressure in the proportioning valve then? So, if that's the case, my proportioning valve is going to be in a default state, meaning no power to the valve, hence no pulsy, meaning no difference between an early valve and a new valve if it's not hooked up. hmmmf
