brake question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by badzr2, Mar 6, 2002.
  1. badzr2
    badzr2 Registered Member
    Jan 1, 2001
    20
    qyestion: My parking brake light won't turn off in my 90 suburban, i check the brake lines. they are all ok, no leaks. i checked the fluid resivoir, its full. What else could it be? I haven't had a chance to look at it too much, just kinda looking for a place to start. thanks
  2. Overkill
    Overkill 1/2 ton status
    Jan 15, 2002
    284
    Orlando, Florida
    Do you have ABS? If so, I would guess something electrical with the ABS system. If not, maybe proportioning valve? Just thinking out loud. Good luck.
  3. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    check the ebrake, may have a kinked cable or it may not have came all the way out so the electronics thinks it's still engaged...also thinking out loud
  4. shawnboy
    shawnboy 1/2 ton status
    Jun 22, 2001
    468
    Toronto, Canada, eh.
    Disco the ABS harness at the master cylinder and see if the light goes out. If it does tthen the ABS is the problem.
    Shawnboy.
  5. K05Aggie
    K05Aggie 1/2 ton status
    Feb 22, 2002
    136
    Dallas, Texas
    When my e-brake light doesn't go out, it's because the pedal didn't come up all the way. I just pull it up with my foot.
  6. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Also check for a leaking wheel cylinder. You have to pry back the dust boots to check them.
