Brake Re-build..hard?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by **DONOTDELETE**, Jun 12, 2001.
    Rotors, Drums, Calipers, Lines, the works...besides the $$ what kind of weekend am I looking at. Degree of diffuculty? Anything I should look out for?
    thanks
    '84 K5
    Chevy in my blood.
  1. thatK30guy
    Jan 12, 2001
    32,076
    55
    Plan on spending around $500.00 on the parts alone. Get the rotors and drums turned down while they are off the truck. If you can get the parts and the rotors and drums turned right away, plan on a weekend to reinstall them.
    <font color=red>I m so we Todd did.
    I m sofa king we Todd did.</font color=red>
  2. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    Well since this sounds like the first time for you to do this,
    do your self a big favor and only dissasemle one side at a time on the rear brakes.
    That way you will have a coplete set to reference when reassemling the otherside.
    It can get kind of confusing when you have a pile of springs and you don't remember how they went. ;-)
    my truck's not dirty, it's earth tone paint
  3. Wait, I have to get the new rotors & drums turned first? I am new to this, but I thought they would be good to go out of the box, damn. oh well, needs to be done
    '84 K5
    Chevy in my blood.
  4. POWERMAD
    Mar 4, 2001
    3,466
    Oregon
    If you are going to be installing new rotors and drums then they should be good to go.
  5. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    If the drums and rotors are new, don't worry about turning them. I learnt the hard way though, before you put them on; get a small sanding disc, I use 1.5 inch or 2 inch dia. discs and some 80 grit sandpaper and give them what is called a "cross hatched"; meaning sand around the rotorin a circular motion all around. Drums are a little harder. This keeps everything from glazing and making neat noises. As for the disc, I got it from Pep Boys. The rotor is a drill attachment and the discs screw into the rotor. Works great.
    "Liberals ain't mean, they just don't have any common sense!"
  6. GRINCH
    GRINCH 1/2 ton status
    Jan 30, 2001
    1,951
    Helena, MT
    Get yourself a brass hammer to pound the lug nuts from the existing front rotor from the outer hub. The new rotors are just that. You could also use a press if available.
    Be sure to get new bearings and seals. The races should be fine. Clean everything really good after dismantling. Don't overdue the grease as it holds heat.
    The Few, The Proud, The K5 Blazer
  7. thatK30guy
    Jan 12, 2001
    32,076
    55
    Ok, I see my mistake. I didnt know you were installing NEW rotors and drums. [​IMG]
    Ok, I have seen and heard few controversies about whether to slap the rotors and drums on if they are brand new. While this may work for most people, some others just go ahead and turn them down a tiny spec just to play it safe. How are you going to feel when you get all finished installing everything and take it out for a test run to find the rotors or drums have a slight warp or wobble in them? Like a jackass! So, just to play it safe, take them to a shop and have them turned down just a little bit. The cost shouldnt run you over 20 to 30 bucks. Just a little safety precaution. [​IMG]
  8. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    FYI, a new rotor attached to a new(or used ) hub, really should be turned(cut).
  9. 79Jimmy
    79Jimmy 1/2 ton status
    May 10, 2000
    214
    Richmond BC, Canada
    I agree you should still turn brand new drums and rotors, particularly rotors. I've seen very, very few run true out of the box. Personally I'd never change a bearing without a new, usually matched race. Being in aviation though I'm a bit anal.
    James
    79jimmy@home.com
