Brake Rotor Question
Discussion in 'The Garage' started by broc944, Sep 14, 2006.
  1. broc944
    broc944 1/2 ton status
    Sep 23, 2005
    1,660
    Northern Minnesota
    I am going to order up new rotors for the Burb from NAPA. I was looking on their site, and I have two choices. $42 rotors and $69 rotors. The $69 rotors are "Noise Dampened Iron". What does that mean?
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    An extra $27.00. I have never heard of such a thing and highly doubt there is a difference worth noticing.
  3. broc944
    Sep 23, 2005
    1,660
    Northern Minnesota
    [​IMG]Brake Rotor Only - Front[​IMG][​IMG]
    [FONT=Arial, Helvetica, Geneva, sans-serif]Click on image to see enlarged view[/FONT]
    [​IMG]Item#: UP 85677
    Price: $68.99
    tax and shipping not included
    Disclaimer: The stated price may vary from the in store price and may change at anytime.
    Attributes:
    # of Bolts:8
    Bolt Circle Diameter:6.5"
    Brake Rotor Type:Rotor
    Discard Thickness:1.215"
    Features & Benefits:Application Engineered to Meet or Exceed Original Equipment Design & Quality.
    Features & Benefits - 2:Manufactured with Original Equipment Vane Configuration.
    Height:2.805"
    Noise Dampened Iron:Yes
    Outside Diameter:12.500"
    Thickness When New:1.285"
    Type of Packaging:Box
    Vented / Solid:Vented
    [​IMG][​IMG][​IMG]
    Add To Cart
    Return to Previous Page
    New Search
  4. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    how much do you drive it. I bought a cheap set of rear pads for my DD instead of GM ones and will never do it again. I only got pads and none of the shims or clips. I reused the old stuff and before long noises started. I have since tuned them out but people ask me all the time wht is that chirping noise. or someone at a traffic light will tell me I need brakes. You could always buy one of each type of rotor and see if there is a difference. only problem with that is if there is then you will probably want to go buy another expensive one. if there is not any difference you will be mad you bought the expensive one.
    Buy the cheap ones and run boggers. that should cover up any noise.:haha:
