Brake Rotors
Discussion in 'The Garage' started by backcountry, Aug 8, 2004.
  1. backcountry
    backcountry 1/2 ton status
    May 27, 2004
    916
    I want to replace my front stock brake rotors. Can anyone recommend a sweet set? Also I would like a pair of sweet pads for the front and shoes for the rear. Any suggestions?
    Thank you! /forums/images/graemlins/thumb.gif
  2. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Wilwood D compound or Raybestos "Brute Stop" pads for the front. Look for grooved and NOT drilled rotors. I know drilled are the fad, they don't stop better, but they do crack better. Chamfers only help on one side of the holes. There's no practical way to chamfer the other side of the holes (in the venting voids). Grooves clean the pad's friction surface and allow what little gases are generated to escape. Outgassing of friction materials is almost a thing of the past.
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    You don't want the "Brute Stop" pads if those are the fleet type pads. They will require heat to get them to work well and in town will not produce the stopping performance of a regular pad.
    Fleet pads are great for heavy duty vehicles because they offer the ultimate in durability and work better when hot than anything else.
    I would just turn the OE rotors and throw a good set of semi-metallics in your favorite name brand on it. That's what I do and I'm very happy with the results.
  4. backcountry
    May 27, 2004
    916
    Thank's guys for the great info.! /forums/images/graemlins/thumb.gif
  5. backcountry
    May 27, 2004
    916
