Brake setup Questions??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Burt4x4, Apr 3, 2000.
  1. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Hey gang
    I will be replacing brakelines and all harware(original 72 stuff is gettin old).
    What is the story with a perportioning(sp?) valve?
    Besides providing a brake warning light, what other purpuse to they serve? Can it be eliminated? Or is that a bad idea?
    I want to boost the breaking power to my tires any tips or tricks? What about 3/4 to 1ton power boosters??
    As you can see I am looking for all the info I can on creating better brakes.
    Rock ON![​IMG] 72 K5 [​IMG]
  2. Burt4x4
    6,854
    Still looking for the almighty Brake wizard!!
    Hellooooo were are youuuuuuu...........[​IMG]
  3. Eagle86K5
    Eagle86K5 1/2 ton status
    Mar 5, 2000
    974
    Whitehouse, Ohio
    The proportioning valve is very neccessary to stopping your vehicle correctly. The front brakes account for approximatly 75% of your stopping power. Keeping this in mind if you were to remove the valve, when you hit the brakes you would be sending equal amounts of pressure to both front and rear brakes. Which most assuradly would cause the rear brakes to lock up . The valve keeps this from happening.
    (from Chiltons)" This valve is used on all models with disc brakes. The valve itself is a combination of: 1) a metering valve, which will not allow the front disc brakes to ingage until the rear brakes contact the drum; 2) the failure warning switch, which tell you if one of the systems has a leak; 3) the proportioner which limits rear brake pressure and delays rear wheel skid."
    <font color=green>Eagle86K5[​IMG]
    <font color=red>Only guy I know that can get out of line in a one car funeral
  4. Burt4x4
    6,854
    OK so that is a bad idea to remove the P. valve!!
    How about booster upgrades, will going to a 3/4 or 1 ton booster/master combo give me more braking power? Is this possiable to swap parts like that?
  5. dremu
    Feb 27, 2000
    15,970
    462
    East of San Francisco
    Don't see why swapping in a bigger booster would help. Sure, you can apply more power to your rotors and drums (prolly warp the poor ****ers ;-) but they only have so many square inches of surface.
    Bigger calipers/pads on the discs (and in the back, toss those drums for discs), now we're talking. More surface area = more stop ability. You might *then* need more pushing power to spread across the increased area, but not before.
    -- A
    '74 K5 Blazer "Tank Grrl"
    '77 Chalet sans Blazer
    and more to come...
  6. Corey-88K5
    Corey-88K5 1/2 ton status
    720
    Home: Michigan, Stationed: Hill AFB (Home of Moab.
    You need to have that valve if you have drum brakes on your truck. Something about drums needing residual pressure on the system. The valve holds the 4-7lbs on the system.
    Corey
    88K5
    [​IMG]<font color=red>Girls Like Guys In Bow Ties
    http://www.geocities.com/corey_perez
  7. Rockblazer
    Rockblazer 1/2 ton status
    Feb 18, 2000
    114
    South Dakota
    Hydro boost is a good option! Rear discs a good option, if you have to replace everything anyway. Make sure to bleed and adjust brakes (rear drums) frequently! Keep your proportiong valve you need it!
  8. snidgen
    snidgen Registered Member
    Mar 5, 2000
    47
    ive got a 72 also and just did the brakes on mine. i got a new everything the master cylinder,proportioning valve, caplipers,wheel cylinders,stainless steel lines. but the one tool i highly recommend is a reverse brake bleeder hand pump. i got mine out of hot rod. it bled my system so well with the new parts it felt like a different truck
