brake troubles
Discussion in 'The Garage' started by babyburb, Mar 21, 2007.
  1. babyburb
    babyburb 1/2 ton status
    Oct 24, 2006
    2,344
    1H North of Dallas
    I changed my master cylinder a couple of months ago after completly loosing my brakes one day. My pedal is starting to get squishy again but I am not loosing ANY fluid. I had excellent braking up until this last week. First my pads started sqeaking and I went to change them but they have over half of the pad left so I left them alone. Then my pedal started getting deeper into the floor board and now they will not lock down even on the floor. So what is happening. I am not loosing any fluid anywhere? Is my master cylinder bad?
    Might be good timing at least. I was about to put on extended brakelines on for my lift and also going to do a 14b disc swap when I get the brackets in.
    Might as well do everything at once.
    Any Ideas?
  2. jaredmajor
    jaredmajor Registered Member
    Mar 2, 2005
    96
    Anchorage, AK
    Yeah i think your master cylinder is gone, same thing my truck is doing right now. The booster only assists in braking effort.
  3. duallyjams
    duallyjams 1/2 ton status
    Feb 17, 2007
    167
    Deale Md
    You already have the plan.Just go ahead and do your upgrade
  4. nemesis_pyros
    nemesis_pyros 1/2 ton status
    Mar 24, 2004
    229
    Winnipeg, Manitoba
    Check to see if the drums are adjusted properly.
