Brake tubing
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by grendel, Jul 26, 2004.
  1. grendel
    grendel 1/2 ton status
    Jul 5, 2002
    287
    Boston, MA
    Alright guys,
    My buddies' try at bending stainless tubing has caused some major leakage. It was a solid effort, but the tubing is just too [darn] thick.
    So, I am looking at buying some prebent shite.
    The only problem, I am running a later model P/V that shold be mounted on the frame, instead of hanging it off the MC.
    the PV I have used two ports for the front brakes instead of splitting the line from the PV like my 71 had.
    Opinions on using a 73 Blazer line kit to fit my 71 Blazer?
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    All the stainless brake tubing (AN -3 stuff) I have bent I did with a cheep ($4) parts store bender and my hands. I never had any problem except when at the very end...so I just left it long till it was bent then cut and flaired it. Is the stuff you are using really made for brake line? The brake line is normally annealed (dead soft condition) so that it flares well without splitting. Does the stuff you are using show a seam on it? My guess it that it is just the quality of line that you are using.
  3. grendel
    Jul 5, 2002
    287
    Boston, MA
    Yeah, it's brake tubing... for airplanes or tanks.
    It's hella thick, which is why it won't flare correctly.
  4. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    just go to the parts store and buy the right stuff, a 60 inch piece is only 7 bucks at autozone /forums/images/graemlins/thumb.gif
