Brake warning light sequence
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by B_to_C, Oct 23, 2004.
  1. B_to_C
    B_to_C 1/2 ton status Author
    Jan 15, 2003
    1,861
    In Government Housing
    On a 1990 Jimmy. The sequence is:
    8 short, 1 long
    What's wrong with my brakes? /forums/images/graemlins/1zhelp.gif
  2. dremu
    Feb 27, 2000
    15,954
    445
    East of San Francisco
    8 short, 1 long
    You have the rear wheel antilock brakes is what's wrong with them. /forums/images/graemlins/histerical.gif
    I seem to recall my Burb doing a code 81 ... now, there are a coupla different controllers. Mine was the Kelsey Hayes, as indicated by the KH on the plastic computer box by the master cylinder and brake booster.
    I seem to recall 81 being a general actuator failure, so I just unplugged the computer and taped the connections up, so as to avoid corrosion, and to turn the light off.
    Could be bad actuator solenoid thing, goo in the lines, lots of stuff, IIRC /forums/images/graemlins/confused.gif
    These ABS systems are pretty primitive, and only work on the rear axle and only in 2WD, so it's not like they're ALL that useful.
    -- A
